need some help with santos
chad904
7/2/19
11
after looking through the catalog and various NWBIG list I've started looking for a Santos that would someday have a real ETA transplanted in and I've found this one but more experience input would be appreciated
https://puretime.io/santos-100-38mm...-white-dial-on-black-leather-strap-a2824.html
is it possible to swap out this a2824?
is this actually the super rep?
also how different is this KZF version?
https://puretime.io/santos-100-38mm...n-white-dial-on-pink-leather-strap-a2824.html
and on another side note, is this smaller version a super rep?
https://puretime.io/santos-de-carti...-dial-on-brown-leather-strap-miyota-9015.html
chocolito
1,663
877
That is the Cartier Santos on the Super Rep list .
The KZF watch is an inferior rep why buy it for the sake of $40 ?
You can swap in a genuine ETA 2824 .
Although i would just get the Asian one serviced and buy a replacement strap . As the straps on these are dog shit , and a massive i'm wearing a rep tell .
Finally the smaller watch you link is the 'NEW' Santos which was released last year at Basel World in 2018 . So an updated version of the first watch you link . A slimmer case , new movement , fast release strap and bracelet system ( on gen ). There are long threads about this watch in the Cartier section . A very good rep by all accounts , but the concensus was there are some noticable tells on the watch ( i think from memory font was too thin ??) .I'm not sure i agree with the consensus opinion , seemed to me the microscope gang were out in force again . So the rep of the previous 2656 model ( your 1st link ) is still considered the best version of a Santos .
To be honest not sure if the first watch is still available or if the V6 factory have changed over production full time to the new model ?? An email to a TD will tell you .
Reactions: chad904
chad904
7/2/19
11
hi choco thanks for answering
i think im set on the smaller 35mm now but still have afew questions
do you think i should wait for a new version of this 35mm with a bracelet or are rep bracelets usually awful?
is it possible to swap out the Miyota for an ETA in the future?
can i just any strap with a springbar?
chocolito
1,663
877
The XL V6 factory version of this watch has already been released with a bracelet . It has quick release and smartlinks ( you can see a video of it on PT ) which looks good . I'm not sure if there are plans to make a bracelet version of the 35mm.
Rep bracelets depend on the rep , some are excellent . You usually get what you pay for as in all things .
No you can't use an ordinary strap with ordinary spring bars . Although i think ZicZac has started or plans to start to make quick release straps to fit the watch . You also could buy a genuine i think i have heard that these fit . HOWEVER i think the straps on the new KOR and V6f are far better than previous versions . much more gen like . They certainly look good in the videos.
You can't change the Miyota 9015 for an ETA different stem length , hand height etc ( people will tell you that you can buy adjusters etc ) . WHY would you want to ? The Miyota will be a genuine Miyota made by Citizen and not a clone . It is a great work horse movement , i have one in a Cartier Tank Solo XL and it is accurate as fuck . The only problem they have a light one way rotor which can sometimes be a little noisy .
chad904
7/2/19
11
Oh yikes the strap using unique to the santos is new to me
quite a big issue if Its so hard to.source a useable band
I.might consider the rolex explorer for something similar thanks!
chocolito
1,663
877
Well the NEW Santos is , because it has the new fast release strap system . If you go for your original choice that uses an ordinary strap with screw in spring bars . However even then you can't buy a replacement strap for that watch off the shelf . You have to go gen or have one custom made . Getting one made is easy there are strap vendors on this site .
