Hi all,
I need help to remove the spring bar from my VSF Pam 616.
As u all know, the VSF Pam 616 has spring bars which can only be removed from the inside. The holes on the outer part of the lugs are faux. U cannot push the spring bars out from the outside.
While changing to this python strap, I forgot to remove the metal tubes in the strap.
Now the tubes are blocking the access to the spring bars. I have no space or any leverage to remove the spring bar from the lugs.
Would appreciate any suggestions other than to cut the tubes and spring bar.
Even if I were to cut them, any suggestions on how to avoid either damaging the watch lugs or the strap?
Thank you very much.
