Need help with discoloration on face
amgerpower
30
Hi,
Have had this PAM 351 for about a year and love the watch. It seems to go with everything and I adore the look! But there is a small dicoloration forming around the center of the watch face that is starting to bother me. It this possible to be fixed, or does a new face need to be purchased?
Thanks!
Raddave
Administrator
67,017
18,637
That is really weird.
I would suspect that the movement has been over-oiled at some point in time and the oil is creeping onto the dial surface.
I would think one of our dial experts will have a better answer than me.......lets hope someone else chimes in !
D
d4m.test
Guest
To me it looks like the dial is slightly bent like an oval (maybe noticeable also on the date window). Somehow it looks to me like the hour hand was/is lightly but constantly scraping on the dial center and polishing it.
Regardless a new dial can fix this, I´d just use it as is most probably and assume it will stay like this (neither get better nor worse).
amgerpower
30
Thank you for the replies.
I think I will try to open the case and see if the face is able to be cleaned. I checked the tolerance from the hands to the face and it looks as though there is enough room to not cause them to drag on the face.
