Hello guys, this is the story. Started with that I bought an UPO from Ruby about a year ago and than about 6-8 months later a lume index dot fell off. I opened up the case and reglued it nicely but instead I dislodged the keyless works
. At the same time when I could not set date or time properly, along with the hack mechanism not working I could not screw the crown down to the case don't know if this is because a stripped crown or tube.
Anyways, I opened up the case and tried to fix the dislodged keyless works and it worked with hack mechanism and everything, until the hack just stopped all of a sudden, and I still couldn't screw the crown back to the case. So I tried to fix it again and what happened was that the dial feet broke along that the second hands broke off.
So now Im left with a semi-broken watch instead![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So what I did was to order a gen crown, gen tube, along with gen hour, minute and second hands.
Am also going to order a new UPO dial or a new dial.
And then send it away so someone hopefully can put it back togheter and maybe fix the keyless along the way.
It might be pricy but still I think the watch will work more properly with some gen items. Does this seem ilke a good choice or Im better off buying a new watch entirely?
