Need help movement SA3235
jacquy
419
97
I have a movement called SA3235, the balance of which needs to be replaced. I cannot identify the exact model. It comes from a Datejust 36 126233 gmf.
It doesn't look like any known 3235. Could someone tell me where to find the broken part or a complete movement, or tell me what movement to replace it with?
I'm really at a dead end. Thanks in advance.
bry168
25/7/23
14
i got the same issue before, i ended up replacing the whole movement to VR3235 from aliexpress. $125. there is 2 types, for sub and datejust.
jacquy
419
97
Thank you friends, this is really the information I was missing.
doctor who thank you GIF
jacquy
419
97
I am offered a VR3235 for submariner, can we change the date wheel of the broken SA 3235 movement on the VR3235 sub to change it to Datejust?
jacquy
419
97
I saw that the constructions of the sub and DJ VR3235 movement are completely different, so it won't work.
Zeta7
1,149
1,170
I bought one of those sa3235 movements off aliexpress for like $50 to practice working on. If you want it with the rolie coronet they’re a few dollars more. I recommend you get a different movement or take up watch repair.
jacquy
419
97
Do you have the link?
Zeta7
1,149
1,170
I tried to get it but no luck. It “zhuman watch component store” and the price is $53.44. You’ll probably recognize the clover shape shock absorber thing on the balance. Hope it helps
jacquy
419
97
Unfortunately neither the VR3235 nor VS3235 are suitable. My movement works with a dial with feet, and the real 3235 clones are a cover with a click. So I really have to find this bogus movement, will it be a 3135?
jacquy
419
97
Zeta7
1,149
1,170
No worries brother. Where about are the dial feet located? We can probably figure out from there what movement you’re needing. For example the eta 2824 movement uses the 12 min and 42 minute position's to attach dial feet.
jacquy
419
97
Yes the dial feet are on 12 &42 but the movement is 28.4mm diam.and 8.5mm thick, and 2824 is 25.xxmm
