Need help identifying movement
Dynaduck
Sales moderator
2,881
575
Hi guys, need your help identifying this GMT movement. Appreciate it a lot!
Rotor has been removed in the pic below
Raddave
Administrator
67,017
18,573
looks to be a 3804B, could be a DG but i cant see the area under the balance wheel
Dynaduck
Sales moderator
2,881
575
Thanks guys!! What's the difference between a DG and non-DG?
junbug5150
4,209
23
DG = Dixmont Guangzhou
It's the factory that actually produces these better quality 21j. Most others are cheap "knock offs".
Boom! Beat Dave ;)
Dynaduck
Sales moderator
2,881
575
Thanks! Have a problem with this movement. I know it's cheap and probably not worth it, but I thought I'd have a look at the keyless since I can't set time nor date anymore. Feels like the gears are skipping. Opened it up and no matter what I do it seems that I cant make the clutch lever to stay in place, not even with the 'cover' over it.
Sorry for noob movement lingo above :)
junbug5150
4,209
23
Yeah you should be able to replace a 3804b for sound $40-50. I don't know if people work on them so its hard for me to say, but is it in the groove of the sliding pinion?
Dynaduck
Sales moderator
2,881
575
Yes it is. But it seems that it skips over it even with it covered. Will check some more tonight.
Dynaduck
Sales moderator
2,881
575
There's no drawings of this movement anywhere? Would like an 'exploded view' or something. First time I'm working on one.
