Need help guys Tag Monaco LS
Steka
1/8/15
Hey guys,i'm kinda new here and i have a problem i think you can help me with?
I've found my tag heuer monaco ls rep today but watch's hands were wobbly so i decided to dissasemble and try to fix it.I removed 4 screws,removed plastic protection,stem,but there was a problem.When i tried to remove the mechanism watch's face moved a little bit.I removed hands but i have no idea how to remove that 'face' and assemble it again.Any help? I have some pics to please check them out.Thanks a lot guys:/
Steka
1/8/15
Bump,help?:-/
Steka
1/8/15
Bumpp[emoji21]
Melikey
23
You probably need to remove the crystal. I have a McQueen Monaco. To get the movement out of that one you need to remove the "bezel" and take the movement and face out of the front of the case. I realize yours is a different case but it might be the same set up.
Sent from my Nexus 7 using Tapatalk
Steka
1/8/15
Thanks a lot for your replies guys,today i am going to try to pull out the dial if it's glued,if not then i as [MENTION=86513]Meli[/MENTION]kev said it'll need to remove the crystal :/ Thanks a lot!
