need help, cleaning Pam 505 inside crystal
Fab_vr6
90
Canada
Hi guys,
I have just received this Pam 505 from a td, however there seems to be a small meTal or plastic shavings trap inside the crystal, at the seven o'clock area. I'm wondering if it is a easy job to take the bezel and crystal out. I ask because comparing to my Pam 111 and 390, which have a small area under the bezel for popping open the bezel,this radiomir style dowsnt have that. Also because of the composite material or whatever material they use in this rep, I'm worried a local watchsmith might damage the finishingwhen trying to open the watch, any suggestions?
SSTEEL
3,803
Any competent, experienced watchmaker won't cause any damage removing the case back and movement. Good watchmakers leave no trace of ever being inside a watch.
Fab_vr6
90
Canada
I'd like to know how I can remove the crystal on this pam, do I have to open it from the case back?
myor
679
13
There is no need to remove crystal. Just take the case back off and remove movement/dial. There are tutorials on the forum you can search.
