I have been fiddling the past 30 minutes trying to get the screw through, but for some reason I can't get the holes to line up correctly. Is there an easy way to do this that I am missing?
Then it should go back on easily. Line up the endlink with the lugs and push the screw in and wiggle the endlink until you feel the screw go into the threaded end and keep preasure when you screw it in. I hope this helps you.
