My Noob PAM243 v3 CG pin question....
bpbp
1,018
248
Hi, I see my noob pam 243 v3's CG pin is kinda little off, do anyone know how to fix it?
Can I just push back to make it flat? Or what what tool can I use?
Here is the picture.
PaMister
192
Just push it in with our thumb and some flat stiff piece of plastic between.
pamdude
180
60 Click Bezel? If so, most likely it's either a Noob or the current H version which is on the same level of quality if not better.
As long as you don't get the older H factory offerings you are fine.
Netbis71
247
It is not so easy to just push the pin in by hand, it requires a lot more force. I released the lever rested cg flat on a piece of wood and took another piece of hard wood from the top (small round piece just on the pin area) and punched it with th hammer, then apply some locktite from the bottom. It will make it flat close enough to be not noticeable (if it ever was flat), however if not, then you may consider pulling it out and chamfer the bottom so it goes in flat as per the thread above.
bpbp
1,018
248
My local watch smith are **** up my CG, he use little hammer and something on the CG, after he done, my CG is look bad. My CG is don't look good anymore. Is any possible to buy all noob v3 CG with anything from TD or someone have am extra like new? I am gonna cry... :sad:
Netbis71
247
Not from TD, but checking m2m section would be better, I have seen cg's there. You could also try to fix it yourself. There are good tutorials here.
http://www.repgeek.com/showthread.php?t=73173
https://forum.replica-watch.info/vb...mary-of-the-best-TUTORIALS-A-work-in-progress
