My mini 3646 build
ocin mreg
89
Hello everyone,
I would like to present my construction to you, a mini 3646.
So, a 45mm case from Ali, a dial and hand from Helenarou, a Chinese movement 6497.
I soldered the lugs and the open case back, the hole for the lugs scew , the tube also.
Replaced the glass by a plexy and of course the whole thing.
The sandwish dial has been modified with resin to resemble it.
I find it nice but it's still a bit big for my arm.
black_shark
3,239
821
Great job!
You could cut the lugs bars a little to help you change the strap when you feel like it.
Enjoy it in good health!
Reactions: ocin mreg
Toofsy
125
57
Nice result.
What did you use to fill in the case back? Same as for the lugs?
Do you have the ref for the plexi?
ocin mreg
89
Nice result.
to solder, you need tin and flux. there is no exact reference for plexy. you have to measure the bezel and take the correct dimensions then it clips because each radiomir kit are different
Toofsy
125
57
Thanks ???? your built is motivating me to use an old plexi riveted dial I found in a drawer
