- 12/5/06
- 1,332
- 3
- 0
Whwn you trim down your rubber strap, cut a 2MMx12MM strip off the part you remove, then super glue it to the strap here:
(I blackened the piece for easier visibility)
this simple fix prevents the clasp center bars from touching the release bar, without any metal working, or bending!!
here's the closed clasp with the fix in place:
The clasp still fits snug to the wrist, as the flexibility of the rubber is quite good..
Works fine, and even I can do it!!
![IMG_2096.jpg](http://i12.photobucket.com/albums/a211/franktrotti/IMG_2096.jpg)
![IMG_2097.jpg](http://i12.photobucket.com/albums/a211/franktrotti/IMG_2097.jpg)
