My first Rep...
simkna
19/8/08
After lurking on these forums for a while, I just got my first rep...
PAM177h with Asian non-swan neck movement. I must say, although it's taken a little fiddling, I've got it's accuracy to with a couple of seconds a day. Very happy with the quality, otherwise - apart from the rep strap had to go. I've put a Heroic18 Poseidon strap on it - absolutely beautiful.
Second rep's on it's way as I speak...
Si.
hubrisin
323
I've got the same one, it's a solid watch. The power reserve is impressive and the light-weight case makes it an ideal everyday watch. Cons, lume sucks but that can be remedied, and the cannon pin will need work if you have the inclination to mod. You've picked a winner, enjoy!
jkirke
101
awesome bro.
darn good looking combo with the heroic strap. where'd you source the watch itself? the dial looks pretty darn good. especially the "L SWISS MADE L" spacing from the 6.
cheers
simkna
19/8/08
The lettering at the 6 is tighter than it looks in the photo. The angle means you are looking at the edge of the 6 hole, making the gap look bigger.
It's just the standard rep from Josh.
Very happy with it, though - especially on this strap.
Si.
