They're essentially the same watch. The question you should ask YOURSELF is which dial color do you like better: green or blue? If you like your bronze with some verdigris, looking like you spend all your life at sea or on the beach, a green dial might pop better with that look. The blue is for landlubbers. Again, this is all totally subjective. Go with your gut.
Or if your gut is big enough, get both.
at least get one based on A7750! I have both... 671 is a bit thinner
I assume 671 will be easier to service on your own in the long run when it eventually breaks down, since it's just a 7750 movement with a plate glued on.
VS 382's clone movement will probably be awkward to replace or fix if broken.
Your contrast of blue vs green is intense!For badass: bronzo 382
for clean and sparkling 671
The PAM671 is a bit thinner because of the P.9010 movement on the gen, which requires a thinner case, and the rep copies that.
Thinner, uh? That's really all the reason I need to persuade myself I'm not buying the same watch twice. [emoji1]
