- 8/6/20
- 357
- 249
- 43
Managed to put this piece together while I was in China and now enjoying it in Canada
The build consist of:
- BP 16710 watch
- Gen 16710 coke insert
- Gen crystal no AR
- Gen GMT hand & aftermarket second, minute and hour hands to fit the VR3186 GMT movement
- VR3186 GMT movement (CHS)
- JF factory 16610 bezel (teeth are less pointy than BP 16710 factory bezels)
Work done by the Chinese watch modder:
- case reworked to fit the VR3186 GMT movement and gen crystal
- Reshaped CG out after steel was added to it (Honestly, I still can't tell a difference compared to it right out of factory and this cost almost $400)
- Gen GMT hand lume refilled so that the color is in line with the new aftermarket hands
- 6 and 9 hour mark rework so they are rounder and more gen looking
- hand base redo so that it's not hollow when looking down from top
- Endlinks were sticking out and looked higher than the lugs. I had him to sand down the edges of the endlinks now the endlinks have the recessed look. But now the endlinks are slightly showing a weird curvature since only the edges are sanded down. I still prefer this looking than endlinks being higher than the lugs. I guess if you are lucky and do your QC right, you can avoid this in the first place
Work done by me (LOL):
- Sand down the case back so it sits lower on my wrist. However, I would have a completely flat case back down to the teeth with no brushed look. I'm satisfied with the result since I'm not gonna take off my watch in the public
- Factory clasp was very tight so I used a screwdriver to loosen it up. Not it goes smoothly when I close the clasp
Work still needs to be done in the future:
- Crystal height is not gen-like. Need to find a higher crystal gasket. I've done my research and I think the gasket from a sea-dweller would work. I will try to order one from JF factory and see how that goes
- Bezel teeth are still not gen-like and still pointy. Also, the outer lower part of the rim should be brushed and not polished. the I can either try to work on the one I have or order a good aftermarket one on a low budget basis
- BP cases have this unnecessary chamfer on four brims of the case. I had the watch modder to remove the polish and they are less obvious. But I'm still hoping to get the case redone and get rid of the chamfers
- DW are not centered. Some gen 16710s don't have centered DWs as well but not by this much. I think replacing the VR3186 DW with a good aftermarket one or even a gen one will solve this issue
The total cost for this watch is about $1400 USD. The only thing that went more expensive than my expectation was the case redo. But at least it's still a lot cheaper than Viet 16710 cases and get the job done by fitting the movement and crystal.I'm at 90% satisfaction level with the amount of money thrown into this project. Labor is supposed to be cheaper in China and the watch modders do a lot of modding every day so I guess they are more "clinically" experienced.
I've modded a daytona 116520, a submariner 116610, a GMT 116710 and an oyster perpetual 116200. They were super easy to mod since I would just swap in gen bezel, dial and hands and no other work is needed. Modding this BP 16710 was fun but frustrating at the same time. But I guess that's what we all enjoy here.
- BP 16710 watch
- Gen crystal no AR
