My almost finished project 111N
prelude
564
started off as a noob 111N and NOW
genuine Panerai parts added
1) OEM Crystal
2) OEM Hands (sec hand is noob)
3) OEM Rachet wheels
4) OEM hour wheel
5) OEM set levers ( all 3 are gen panerai)
6) OEM CG screws
7) OEM incabloc
8) Gen dial
Parts modded to look gen
1) Cannon Pinion
2) Swan Neck ( see curve added to tip)
3) polished sides of bridges
4) case lugs were fixed to look gen
mysterio
9,794
866
I can't tell if your incabloc is OEM from the blurry pictures.
Bozz
2,748
Your OEM Rachet wheels bevels are not polished as gen...
Bozz
2,748
You need of a swan neck long screw, a slim crown and prev hands...
prelude
564
Bozz I know this watch needs still more works. Also trying to find a way to do platinum plating.
ALE7575
Section Mod
19,846
423
Congrats prelude !
This is a very nice job and a very good Franken
But, if you are looking for perfection:
-Neither Incabloc nor Lyre spring are gen. No doubts about that
-The Swan neck spring is a bit used and you can see the brass material instead of SS
-Micrometric screw is short
-Fat crown and non Pre-V Type hands are not appropriate for a N-series
-Wheels and gear train need more works (I doubt, only doubt, they are gen)
-You should change the wheel screws.
ALE
Bozz
2,748
Congrats prelude !
ALE
Yep! it looks like a Goin or a Marlin modded mov
