My 390 in a 111n v3 case....
tranzmizzion
1,598
Just got it back from Speedy who did the swap... and put the hfac cased 111n up for sale.
Added an orloff asso strap, and I'm lovin it.
You likey?
karesz501
1,985
European Union
Nice one there, have the same setup but used the 111n dial as well, believe me its a real beauty, don't "waste" it!!! Look at my 'hybrid' thread, that dial is amazing!
edit: is that an Orloff asso strap?
stonesix
409
You likey?
Hi tranzmizzion,
I too have 111N noob-fact case and h-fact Pam390, just wondering why can just exchange the CG from Noob fact to Pam390?
Is there anything else that better other than the CG from Noob?
thanks.
tranzmizzion
1,598
Hi tranzmizzion,
thanks.
I don't know. I think the case is a bit "sharper" but who knows. I had 111n v3, I had 390... Sent to speedy g and said "swap".... Nice and easy....
mysterio
9,794
866
The crown needs to be swapped too. Noob CG doesn't work with Hfac crown
H-Factory Crown is too fat and the lever won't close. You'll have to swap, at the bare minimum, the CG and the crown. If you want to do the whole enchilada and swap the case, it's optional.
karesz501
1,985
European Union
When I swapped the 111v3 case onto my 390 inner parts, I definitely kept my H fact crown.... The noob crown/stem was rubbing against the cg when pulled out.
The H fact sits nice, no issues. It works;)
