- 27/11/18
- 97
- 31
- 18
Hi Guys,
I hope to get some help about this movement: I was trying to make some small adjustment since the watch is going a little too fast gaining > 30" / day but I was not able to discern the usual levers on the Balance. The only one I saw was what looked like the Regulator / or perhaps the Stud as I do not know if the actual 8400 uses the same system on some Rolex to adjust the weights on the balance wheel instead of a Regulator pin (no need to adjust the stud since the Bit Error is almost always at 0ms!).
I tried to push it counterclockwise a little, but it did not move, so using the tweezers I made a little more force and the piece just popped off: on close inspection I see some glue traces so I suspect this is a fake Stud and possibly even the Bridge is not real but before removing it and check if the real regulator is connected to the balance below it, or if I can just glue this piece back (it doesn't seem to stay in place just by friction...) I really need some advise from the experts.
TIA
Cheers
PS I love the watch in spite of having the incredible Thirty-Nine (39) Jewets!
TIA
Cheers
