Miyota 9015 Running Fast
ward1991
Looking for Noob 116610 sub bracelet💚
3,373
3,260
Rust Belt
Brand new MK Iwc mark xviii with 9015 in it.
Running extremely fast since delivered. An hour or more ahead after only a few hours from being synced up with atomic clock
My first thought was magnetized, put it on the degausser, no joy.
Then, I attempted to regulate it. At first my adjustsments seemed to get her closer to normal for a few days, only being fast by a couple minutes for a 24hr period, then it went right back to its old ways at some point.
I am out of room on the (-) side for the regulator ring.
Whole servicing needed or is there something I am over looking?
Thank you
Sent from my SM-G950U using Tapatalk
ward1991
3,373
3,260
Rust Belt
Fireblt
I'd either service it or replace the movement, depending on how confident you feel.
Should be an easy swap
Sent from my POCO F1 using Tapatalk
Rx4Time
Supporter, Panerai lover
12,047
10,852
I had one where the hairspring wasn't installed correctly which ran erratically fast. Do you have a timeographer?
ward1991
3,373
3,260
Rust Belt
I need to invest in one :/
Maybe that's my issue. Were you able to tell from an inspection that it was fudged?
ward1991
3,373
3,260
Rust Belt
Visual inspection*
ward1991
3,373
3,260
Rust Belt
I'd could probably handle a swap. I'm notorious for fucking up (my own) datewheels though. I've never tinkered with a miyota however.
Rx4Time
12,047
10,852
That one was a while ago. I remember the spring did look malformed as it oscillated. I sent it out and the watchsmith was able to straighten it out and reinstall.
Reactions: ward1991
witchywatch423
24
Hoping to revive this thread.. my 9015 is running ~145 spd fast. It the app on my phone indicates a change in magnetic charge when I move the watch near the sensor, but not as much as a real magnet. One of my other watches doesn't register at all. Do you think it's likely magnetism is the issue?
R2L
3,667
1,385
More than likely. You can take it to a watch smith who will demagnetize it for you, or you can buy your own and do it yourself. If that does not work, you’ll need to get your movement serviced or replaced, as mentioned above.
Reactions: witchywatch423
witchywatch423
24
Thanks, I'll probably buy one on amazone and see if that does the trick! Will let you know
ward1991
3,373
3,260
Rust Belt
I tried de-magnetizing and no joy.
I ended up putting in a new movement.
Sent from my SM-N960U using Tapatalk
R2L
3,667
1,385
I had one like that as well that would not demagnetize. I took it to a watchsmith who opened it up and found rust on many of the moving parts. Once he serviced it and cleaned the rust off, it ran well. Cost me almost as much as a new movement. In your case, if demagnetization does not fix the problem and it is a swiss movement, I would consider getting it serviced. If Asian, throw it out and install a new one.
