- 5/4/18
- 24
- 2
- 3
Thank you for your help!Chances are very good the rotor is just friction fit. You can read more about this type of inexpensive movement rotor repair in the thread below.
It's probably possible to fix it in the case but much less risky if you remove the 3 screws and reassemble the rotor out of the case. The video referenced in the thread shows this being done.
Automatic Movement Rotor Repair Fell Off!
Hi all, Dropped my watch and the rotor fell of the movement. I tried pushing it back on and it keeps falling off. Obviously I should not glue it, but does anyone know how to fix this? Or am I better off just taking it out completely and only using the winder? I would prefer automatic without wind...www.watchrepairtalk.com
You can buy a set of jeweler's screwdrivers for very little €. Placed flat on a bench, the rotor could likely be pressed or gently tapped into the axle with a jeweler's hammer.Thank you for your help!
That was an interesting read. Unfortunately I cannot unscrew the 3 little screws as they're really really small and I don't have the tools for it. I figured that if it popped out I should be able to pop it back in... But after much effort (I can't press any harder) I guess it's just not possible.
I'm trying to find a watch repair place that can fix it for me. I can't find any from the RWI list of watch makers/fixers that are from France where I live. I'll give a b&m watchmaker a go.
Got it, any suggestions on where/what to buy?You can buy a set of jeweler's screwdrivers for very little €. Placed flat on a bench, the rotor could likely be pressed or gently tapped into the axle with a jeweler's hammer.
Hey thanks for all your help... Really.New 0.6mm-2.0mm 8Pcs Watchmakers Multifunctional Opening Repair Tool Set Precision Screwdriver Watch Glasses Flat Blade
Color C
Mini Hammer Watch Band Watch Strap Bracelet Advanced Hammer Jewelry Watchmaker Repair Tool Watch Maintenance Hammer
