Manual winding metalic friction noise + auto windong short power reserve
anon10500
36
My subc rollie has 2 movement problems:
1- When I try to wind manually, there is noise coming like metallic surfaces touching each other. Actually it is kind of hard to wind manually.
2- Power reserve from automatic winding is not great. Watch needs to be worn daily in order to not stop it.
Any ideas/similar experiences.
Thanks
cybee
11,134
30
I would remove the rotor and the auto winding bridge and check to make sure all the gears are functioning correctly along with the rotor.
