- 12/3/18
- 36,997
- 77,305
- 113
Sometimes rep factories use annoying methods to attach rotor screws. The VSF 3235 has one with a triangular hole in the rotor screw head. Some ARF models and others can have this arrangement also.
You can make your own removal tool pretty fast if you have a dremel and an assortment of bits or Allen wrenches lying around. Just grind the bit into a triangle head and voila. These won't win any beauty contests but they will get the job done.
