Lug Pins to Hold Strap
jumpope
300
Nashville, USA
Guys, I am new to PAMs. Been modding Rolex reps and working on movements for years, but I just received a new Noob PAM 297 and I really love it.
My question is with the new locking mechanism on the Noob that holds the strap pin in between the lugs. One of mine does not lock the pin in. Is there any solution to this or is there a spring Bar that would work. Is it something that I could fix. It does not seem to want to fall out, but if you push on it, it will come out without pressing the locking mechanism.
Thanks!
silverclaw
1,132
Get a pair of 24mm springbars, panatime if you're from the us, cousins if you're from the uk/eu.
ALE7575
Section Mod
19,846
423
As said by silverclaw buy spring bars from Panatime
There are even spring bars simulating the screw bars
ALE
khador
56
I bought some spring bars from a strap maker called Micah, they're perfect:
http://www.vintagerstraps.com/zspr/spr.html
I got these after getting some from WSO on ebay that were a bit too short, they didn't sit flush at the non-screw end.
Sent from my Nexus 7 using Tapatalk
