looking for replacement movement for gen Omega De VillE
Ko67
1,223
119
Why not have the genuine omega movement repaired by a competent watchmaker? It just does not seem right to downgrade a gen deville to a franken... but to answer your question the omega movt in the dville is based on eta 28xx architecture and any 28xx clone could be made to fit by a good modder. But, for the cost if the donor and the work, you might be able to repair the gen mvt.
Sent from my iPad using RWI
JOP
703
179
as Ko67 said, you can fix your movement, you can find a used one for parts, you can find a clone etc.
Whatever you decide, don't loose the gen movement at any cause.
Have in mind that, gen or clone, you need to service them sometime.
JumpiterT
148
51
sure I got a quote of $500aud to repair it. I just thought that it would be cheaper to replace the movement with a rep. not sure what your thougts are.
Rx4Time
Supporter, Panerai lover
12,176
11,333
You'll devalue the watch and end up spending comparable to having it serviced. Why not send it to one of our forum watchsmiths to have it serviced and repaired? it'll most likely be less then the quoted price from Omega and retain the watches value.
marrickville
413
182
Australia
what model is your deville? is it the co-axial 2500 or 8500? or the older 1120 caliber?
attached some pics so I can help assess. I'm also Australia based.
trailboss99
Head Honcho - Cat Herder
Administrator
43,901
20,137
Have it fixed mate, once you do that to it it's worth nothing. Also some models of the De Ville used a super thin MVT, nothing else will fit them. I have one I could sell you but by the time you bought it and had it serviced it would be cheaper to have yours done.
JumpiterT
148
51
Hey dude here they are
