Laser Rolex Crown
anne_nrw
334
56
Does anyone know if you get the watch glass with the laser crown for the SUB as a rep or if you depend on the gen part?
Anne
QueTip
14,713
6,197
Ecender
572
298
Miami, Fl
I believe your question is if a Sub rep crystal comes with the laser etch crown, if that’s the case yes. A Gen one is a better quality though.
p0pperini
Uses Too Many Big Words
9,652
35,525
Rolex reps have had the LEC (Laser Etched Crown) for years. The quality is variable. On some cheap reps, you can see the crown etching from across a room. On good quality reps, you’ll need to compare the LEC directly with a gen, under a loupe or microscope, in order to spot the difference.
Reactions: YellowFin
anne_nrw
334
56
Hi thank you! I Must buy a magnifying glass to see if the VSF Sub has the laser crown at all!
anne_nrw
334
56
I hope it is at the VSF gen like :)
