KW/V6F PAM586 Q "Tribute to Brazil" Pictorial Review. [Pics Heavy]
shewie
513
22
London
PICTORIAL REVIEW
of
LUMINOR MARINA
GMT
GEN Luminor 1950 PAM586 Q GMT
RSP:11500USD
More Information about GEN Realase
KW586 / V6F PAM586 Q "Tribute to Brazil" Edition
Information about the model itself:
LUMINOR 1950
KW PAM 586 BRAZIL
GMT
PANERAI LUMINOR 1950 CASE 44MM
Case Material :
GEN. 316L STAINLESS STEEL BRUSHED FINISH.
Case Diameter :
44 MM
Movement :
SPECIAL MADE LOOKS LIKE PANERAI IN-HOUSE P.9001 MOVEMENT. BASED ON A-7750 AUTOMATIC. 28.800 VPH
Functions :
HOUR , DATE ,GMT
Glass :
SAPPHIRE GLASS %100 SAME SPECS.WITH GENUINE
Dial :
BLACK DIAL WITH SUPER LUME
Bezel :
SMOOTH. POLISHED
Bracelet :
BEST QUALITY CALF LEATHER
Case Back :
SOLID CASEBACK.DETAILED ENGRAVINGS
Clasp Type :
TANG BUCKLE
Water resistance :
YES
Watch comes from KW/AMANDA
Absolutely perfectly finished REP by KW, hardly visible any difference with the gen, which is also a pretty rare watch.
Limited Only to 50pcs.
This rep was released in its current version in Q1 this year. (A.D.2015)
So it's one of the latest relases from KW known as V6F
Let's see it a bit more in depth:
Crystal is sapphire with colorless single AR. As usual with most PAMs (gen and reps),
AR is not the best and the crystal catches reflection of the surroundings pretty easily. No readability problems though, and it's really colorless.
Dial to me looks flawless.
Hands lume application on this rep seems to be perfect.
The 586 Q features a black sandwich dial with small seconds at nine.
The color is spot on as far as I can tell, so are the numbers and hands shape. The sandwich effect is deep and the dial itself has a nice semi-matte finish.
Inscriptions are correct, crisp and glossy.
CP is not perfectly flush, but the flaw is barely noticeable by naked eye.
CG shape is brushed and almost perfect as usual with KW reps, inner corners are sharp and fitment is just perfect. Lever shuts tight with a nice click.
Location of CG engravings and engravings itself looks correct.
I cannot see differences between KW case-set version and gen photos. Brushed with polished bezel finish, it’s directions etc. - looks exactly gen-like.
From side it may look pretty thick.
Caseback is closed on this rep, engravings are deep with "Tribute to Brazil" engraving and it seems to be in correct size and placement of inscriptions.
well known A-7750 based P.9001 movement without working power reserve and 24h GMT function instead of GEN 12h GMT
As the PAM586 uses an Asian7750 movement, the GMT uses the day wheel to advance, so it's a 24 hour.
The gen PAM586 and other GMT has a 12 hour cycle.
Tang Buckle is brushed and finished preety good with PANERAI logo in the middle
158g weight with strap
it feels pretty solid and has a great gen-like feeling.
Not the best finished inside part of the caseback.
Apart of that
-CONCLUSION-
All in all, I can only say this is surely one perfectly finished watch made by KW, exeptional caseback design. I'm very happy I had the opportunity to buy one.
The look and feel are exceptional on the wrist. Definitely a first class bordering super rep and a must for every PAM lover!
It's my first review so please give me a small credit at start.
Hope you enjoyed and You will find this small review useful.
:welcome:
#Lume Shots will be added Tomorrow.
Reactions: Rajgon
AP_VC
373
This one totally flew under the radar, I'm glad someone finally reviewed it, thanks for your time...
kilowattore
14,141
6,822
Great review, very informative, and about a not much discussed watch. Definitely useful and well written!
ALE7575
Section Mod
19,846
423
Thanks Shewie for this nice and informative review
The closed caseback is a good advantage for the evaluation of this rep
Unfortunately the Gen GMT function of 12 hrs is currently impossible to be repped, that is an evident flaw of this nice rep
If no more evident flaws I could agree about a First Class bordering Super rep status or High level due to GMT difference
I will include this link in PAM GUIDE
Thanks again
ALE
