KW PAM382 green pearl DIY fix
ernien
799
193
Canada
Although I loved my KW 382, I received one from the earlier batch with the green pearl. And you know how it goes, once something starts bothering you on your watch, it's all you look at! So with ZERO re-luming experience I figured why not give it a shot. Here's my comparison of two lume kits for others in the same situation.
Although I don't have any before shots, the pearl was obviously green and looked the same as others have received like member momo_sweden.
I decided to buy two relume kits to compare. The first was the AF Swiss (C1) lume kit in white from esslinger.com
http://www.esslinger.com/luminovas-fluorescent-compound-kit-with-white-glow-in-dark-paint.aspx
The second kit was from NoctiLumina, the "white color body with green glow"
http://www.noctilumina.com/index.php
AF on top, NoctiLumina on bottom. AF was more pure white, while NoctiLumina was slightly greenish.
AF on top, NoctiLumina on bottom. NoctiLumina was slightly brighter than the AF.
So although it wasn't the brightest, my goal was to get a white pearl so I went with the AF. I removed the old pearl by carefully scraping it with a small blade until it crumbled and came out cleanly. I won't go into the re-luming process as there are plenty of YouTube videos by the experts, however, I do recommend reluming the pearl in two stages because as it dries it shrinks slightly.
End result:
So not perfect but not bad for a first try and it was lots of fun doing it!
ernien
799
193
Canada
Great job!
Is it flat or slightly convex?
Thank you. The pearl is flat like the ZF which was the easiest way to do it as a beginner. I know the gen is convex but every time I tried to do it that way when it dried there would be a little dimple in the middle.
kilowattore
14,137
6,810
Good job and thanks for sharing your experience.
I don't think I would have been brave enough to try :)
flounderpounder
139
looks great bro! I'm glad it worked out for you and i think it looks a lot more gen like. I noticed from pics that a lot of rep pearls look very rounded almost like there was a little marble of lume in a little cup of bronze. where as the gen pics it looks more flat almost like a tiny unused chapstick. Your's now has that look. :)
ALE7575
Section Mod
19,846
423
Very nice job ernien
I'm going to include this link in PAM GUIDE as a DIY mod
Thanks for sharing
ALE
