Hi folks:
I've noticed that the KW pam luminor I've got - when compared to 2 of my other Noob luminors- the CG lever snaps down a lot weaker. I did read on Ale's guide which says this is one of KW's feature. I did make sure all the screws are tightened...etc
Just wondering has anyone noticed any difference in water resistance due to this respect? Maybe the crown isn't pressed in hard enough? I know you can get pressure tested...etc but at the moment that's not available at where I am at and all I do is re-lube the CB seal and crown seal and hope for the best.
Comments appreciated
