KW 312 (not so) short review [PICS HEAVY]
kilowattore
14,046
6,564
Luminor Marina 1950 3 Days automatic - PAM 312 KW
Model: PAM 312
Maker: KW
Movement: a7750 28,800 vph decorated to look like P.9000
Dealer: Hont
As soon as I saw the new v2 with Seagull movement become available with the subsequent price reduction, I decided I had to have one. I missed a 44 mm 1950 case in my collection, and this is one of the most recommended reps, so the curiosity was great.
Moreover set2374 posted this nice review of his own 312 here, motivating me even more to try it.
I can only thank you guys for advising this acquisition, it's an amazing watch indeed!
Needless to say but, even with some unavoidable flaws that come with any rep, the most part of the inaccuracies are almost unnoticeable in real life and detract nothing from a very well executed rep.
THE GEN (312 Q series)
The 312 is part of the contemporary collection, and sports a 1950 brushed case with polished bezel.
Dial is black with silver hands and features a seconds subdial @ 9 and date @ 3.
Movement is the automatic in house caliber P.9000, same as used in PAM 382 and many others.
The P.9000 beats at 28,800 vph and has a quick hour set function, meaning that you can move the hour hand without moving the minutes hand, nice novelty and exclusive of the gen because no rep movement is capable of such complication afaik.
One little thing I noticed during my research for this review is that the first series (L series I think was the first) featured a fully polished caseback, while the current series (Q is the latest I found) has brushed caseback with polished sides.
As well as the rep, the gen is reported to be thicker than other PAMs due to the automatic movement.
THE REP
At first glance I noticed the nice effect given by the contrast of brushed case, polished bezel and matte dial. It recalls the design of PAM 127, of course in smaller size and without the distinctive domed sapphire.
The watch feels and wears noticeably bigger than Luminors of the same size like the 390 or the 563, mostly due to its thickness. CG feels a bit bigger too.
CASE
PAM312 features a 44 mm 1950 case set with brushed mid case, polished bezel and brushed display caseback.
The quality of the build is exceptional and the feeling is completely satisfactory.
The highly polished bezel contrasts nicely with the case. Just like inPAM 127 the bezel is raised from the case, not flush like in Luminor cases. Well, a pic might explain it better :)
As far as I can tell the case shape is almost perfect, lines are sharp and curves appear correct to me. Lugs are quite close to gen as well and join the case clean and straight. Lug holes placement looks ok, maybe a hair too close to the upper edge, but it's a matter of microns ;)
Here's a detail of the zone of the lugs, notice the brushing and the beautiful shapes :)
CROWNGUARD
CG in PAM 312 is 1950 style, with "REG. TM." engravings on the front side.
In the inner upper part of the CG you can notice a zone where the meta lhas not been perfectly filed, I think this is a "defect"(if I can call it so) of my watch only, and luckily it's invisible in real life.
CG pin is ever so slightly raised, but in some gen pics I saw it looks to be a little recessed.
REG. TM. engravings are deep and defined, fonts are correct as far as I can tell, but are placed a little too much on the outside.
CG edges are slightly rounded and polished, maybe a tiny bit more than gen. While thisfeature is only noticeable in macro pics, it will give the CG a well defined look and make it more comfortable to wear because it won't “scratch” your wrists. This is one of those micro details that only the best rep feature, and are the things that give a rep that famous "gen-like" feel IMHO.
GEN CG:
REP CG:
The lever shape is good, but the tip is a bit too far from the case, again just a hair, but it's perfectly flush with CG body when it's closed. Closing does not have the right feel, though. It simply does not snap as tight as I would like.
Crown looks very good, with polished and nicely machined teeth.
DIAL
The black sandwich dial has modern lume, seconds at 9 and date at 3. Indices and numbers are sharply cut, date window also. Date is centered and changes gradually starting around 10 PM.
Printing is crisp but could be slightly more raised and glossy, something I noticed in my 382 as well.
Regarding the LUMINOR MARINA and PANERAI inscriptions, I can confirm they are a dark yellow/orange/brown color, while gen has a more subtle cream/beige tone.
HANDS
Hands are silver, well finished and polished. Hands lume is slightly more white than lume on the indices.
CP is polished and almost flat, ever so slightly recessed, one of the best in my collection anyway :)
LUME
Lume is quite strong and long lasting for rep lume.
CRYSTAL
Crystal is slightly curved, height and shape look fine to me. AR is good and almost colorless, even if in particular light conditions a shade of purple appeared. All in all very good imho.
CASEBACK
GEN:
REP:
The display caseback is brushed with polished sides, as per latest gen series.
Again the brushing is top notch, as well as the engravings, which are deep and crisp.
The movement is an a7750 decorated to look like the P.9000 inhouse Panerai movement.
The rotor and the plates covering the movement are very well machined and look very good. The blue colored text is deeply engraved, even deeper than gen, fonts look correct.
P.9000 inscription is inverted compared to gen but reads in the right direction as per KW choice (ZF P.9000 has same text direction as gen, but due to its position it reads inverted) .
Upon close inspection, some defects in machining near the screws and around the faux escapement wheel can be observed.
The balance wheel at 11 is an instant tell on this movement, it is placed at 7 in gen. The new Seagull movements used in KW 312 v2 instead features a balance wheel at 6 which can be considered a slight improvement, yet it is still wrong.
I suspect that seagull versions might be thinner than corresponding a7750 versions, but I have no way to confirm it atm and I could very well be wrong.
Very nice looking movement nonetheless :)
BUCKLE
Buckle is standard screw in, good quality brushing and crisp PANERAI engraving. The space for the tongue is slightly bigger than the tongue itself, as I recall gen buckles are obviously perfect ;)
Panerai code is etched on the back side, but tbh I don't know if it is the correct one.
CONCLUSIONS
The looks and feel of this watch are really hard to match, the only thing I can advise to consider before buying it is its size: even though it's the same size as a modern Luminor, the thickest case makes it wear quite bigger on the wrist.
Color of inscriptions on dial and rep movement are the biggest tells, but they are pretty minor to me and totally acceptable, almost impossible to spot without owning the gen side to side or in presence of an expert of the brand imho.
Another great PAM added to my collection, it has grown bigger in the last few months and yet I can't stop being amazed how nice and well made they are. Now onto the search for the next one! :partybanana:
Additional pics :)
As usual I hope you found this helpful and enjoyed the pics, let me know what you think of this great rep and don't hesitate to correct me if I'm wrong, I'm always happy to update the review :)
:cheers:
Abba Zabba Zoo
496
13
Great watch Kilo, and even better pics. You obviously put a lot of love in that. I own one, too (albeit a 7750 version), and after 1 year the watch is still growing on me. For some reason I've always found it difficult to mount a suitable strap on it. You have found a good solution to that, IMO. Thx for sharing.
pm-guy
Member
4,620
4,048
Thanks for the awesome pictures and review :)
kilowattore
14,046
6,564
Thanks for the kind words guys :)
Mine is 7750 as well. As a matter of fact I asked my dealer for the seagull version, but received this one instead. I bet sometimes dealers have a hard time keeping up woth all updated models ;)
Regarding the strap, I feel this is a "strange" watch: despite its thickness and the 1950 case, which should bear some vintage heritage, the watch is amongst the most modern and elegant PAMs I saw. Maybe an alternative could be a classic Pre-V brown strap, surely not a watch that goes well on vintage leather :)
kilowattore
14,046
6,564
A couple of wristies from today, in order to show its colors in daylight :)
pm-guy
Member
4,620
4,048
For this KW Pam312, may I ask which series is yours?
I recently bought one which was a O series, ending up returning to TD as the CG lever is little loose...
kilowattore
14,046
6,564
It's O series, my crown is not loose but neither it is as tight as my noob 372
pm-guy
Member
4,620
4,048
Thanks... I may have to try my luck again with a new order.
kilowattore
14,046
6,564
I think you might have to go forth and back a few times before you find a tight one, it seems to be a hit and miss thing.
Good luck anyway ;)
ALE7575
Section Mod
19,846
421
Thanks kilo
This is, as always, a nice review with fantastic pics. They show perfectly the essence of this awesome watch
I will include this link in PAM GUIDE and again rep points added
Congrats for your job
ALE
PaMister
192
Crown lock action could be improved by sanding bottom of the crown quard slightly. Just take a piece of sandpaper, put it on a flat surface and rub CG against it one end by time. It won't need much and improvement is significant. Be carefull with screws, mine were stripped and I had to replace them. KW case does not take original 2mm screws but smaller 1,6mm screws.
kilowattore
14,046
6,564
Thanks ALE and thanks guys for your kind words :)
Congrats on the purchase. ZF has a new version with the new ZF movement.
Link?
I could find only the older version with old movement.
Imho, though, the kw v2 with ST2555 is really hard to beat with a price tag under 280 usd. :)
cosmicgate
439
Link?
It was only released last friday. With the national day in China it will be announced this or next week. I only momentarilly saw that the movement was the new zf used in 382. The rest seems to be the same. I'll wait for more members to chime in on this.
On a seperate note i also saw the N-fac 417 and KW 111 (at least that was what the factory told me). The 417 uses the n casing and crown guard. No blue AR like kw 417.
Sent from my SM-N9005 using Tapatalk
kilowattore
14,046
6,564
Let's see how this new ZF 312 is, of course there's still room for improvements :)
Noob 417?? Wow, that would be good news indeed!
