IWC Spitfire Double Chronographe
serumphy
33
Dernière acquisition chez tony(mon revendeur habituel, toujours sérieux), en vue de la porter sur mon lieu de travail (hôpital).
Plus sobre et moins mastoc que mes acquisitions habituelles (très voulu !), je trouve qu'elle a beaucoup de classe.
Ses caractéristiques :
Made with a Genuine Watch as Sample.... Refer Side by Side Pics... 1 : 1 Against The Genuine On External and Internal Casework... Genuine Movt Can be Ported Over... Totally Interchangeable!!! Origial Superlume C1 on Markers and Needles... Limited Initial Stocks!!! Immediate Delivery!!!
[FONT=Verdana, Arial, sans-serif][FONT=verdana,arial,helvetica,sans-serif]MOVEMENT:Asia 7750 Valjoux Working Chronograph movement, Anti-Magnetic Cover , 28800bph, Working Regulator, Two Chronograph Sec Needles, One on top of the other... Both will move and reset at the same time
[FONT=verdana,arial,helvetica,sans-serif]CASE DIAMETER:
[FONT=verdana,arial,helvetica,sans-serif] 44mm
THICKNESS: 16mm
DIAL COLOR: Metallic White Dial with Black Subdial and Embossed Luned Numeral Markers, Original C1 Superlume on All Hour Markers and Needles
CASE MATERIAL: Solid Stainless Steel 316L, Same Tone, Density and Weight
BRACELET: Premium Calf Leather Strap (Croc Print) with Brushed Steel Buckle
FRONT GLASS:
[/FONT][FONT=verdana,arial,helvetica,sans-serif] Sapphire Crystal with DOUBLE AR, Swiss Standards, Done by Vendors who commission work by Renowed Swiss Brands
BACK GLASS:
Solid Close case back with Detailed Spitfire Graphic Engraving
Individual Live Serial Numbers and Matching Manufacturing Nos
HACK MOVEMENT: Yes
CLASP TYPE: Normal Tang buckle
DATE INDICATOR: 3:00 (Datewheel Font and Size is the same as the Genuine (Refer to Day 11)!!!
[/FONT]
[FONT=verdana,arial,helvetica,sans-serif]Water Resistant
Running Secs at 9:00 Subdial
Chronograph (Faux Split Secs)
Note: All Parts of the watch can be totally interchangeable with the Genuine watch
[/FONT][/FONT]
[/FONT]
[/FONT]​
http://www.asian7750.com/cn/product_show.asp?big_pid=&ps_id=110&P_id=2241&ti=
Mes photos perso (en HD, cliquez pour agrandir) :
La montre dans sa globalité (avec son bracelet cuir, très aviateur):
Au poignet :
J’apprécie beaucoup le travail réalisé sur les chiffres du cadran (en relief)
Photos de moins bonne qualité (sans flash)
La gravure du fond est très belle, et d'après l'annonce, chaque serial number est unique...
44mm ca reste tout de meme imposant.
Une épaisseur sérieuse tout de même.
L'affichage de la date et du jour de la semaine reste suffisamment atypique pour le mentionner !
Inushuk
5,500
En effet jolie acquisition... elle me fait penser à la St Ex ...
Son dial blanc et ses chiffres en relief lui donne de l'allure ...
Une question tout de même ... Quel est l'usage de la 2nd "aiguille seconde chrono "
serumphy
33
Theoriquement en pressant le bouton a 10h sur l'originale on la fait stopper et l'aiguille metal continue son chemin. ("double chronographe"). Malhereusement ici ce bouton ne sert a rien et les deux aiguillent tournent strictement en même temps.
A moins que la pression du bouton a 2h ne fasse partir que la metal, et la pression du bouton a 10h fasse partir la rouge (ce qui serai après tout assez logique). Je nai pas reussi a trouver l'explication exacte de la fonction "double chronographe" de l'originale.
On peut pas tout avoir ^^...
Ed911
5,464
56
Ça donne envie d'aller à l'hosto cette belle IWC ;-)
lambor
2,107
Effectivement très joli montre ,félicitation et profite en bien :):):)
zewatch
2,425
Bien joué , à l'hosto ça passe ni vu ni connu ( tu ne pourras tout de même pas échapper aux regards en coin de quelques amoureux de la marque ou amateurs de chrono curieux ;) )
ZW
LFH
1,004
Inushuk;1226510 Une question tout de même ... Quel est l'usage de la 2nd "aiguille seconde chrono "[/QUOTE said:
c'est ce que l'on appelle un chrono avec rattrapante, c'est pour pouvoir marquer le temps intermédiaire.
je n'irais pas à l’hôpital pour la voir :goat:
cela dit , très belle montre,
Inushuk
5,500
Merci Laurent ...:)
Je me doutais que c’était une rattrappante mais j'aurais été très surpris de voir une Rep avec cette fonction "fonctionnelle"
