IWC Spitfire 371806 Doppel Chrono -H-Maker === 316USD
http://s1178.photobucket.com/albums...C/IWC Spitfire 371806 Doppel Chrono -H-Maker/
Made with a Genuine Watch as Sample....
MOVEMENT: Asia 7750 Valjoux Working Chronograph movement, Anti-Magnetic Cover , 28800bph, Working Regulator, Two Chronograph Sec Needles, One on top of the other... Both will move and reset at the same time
CASE DIAMETER: 44mm
THICKNESS: 16mm
DIAL COLOR: Metallic White Dial with Black Subdial and Embossed Luned Numeral Markers, Original C1 Superlume on All Hour Markers and Needles
CASE MATERIAL: Solid Stainless Steel 316L, Same Tone, Density and Weight
BRACELET: Premium Calf Leather Strap (Croc Print) with Brushed Steel Buckle
FRONT GLASS: Sapphire Crystal with DOUBLE AR, Swiss Standards, Done by Vendors who commission work by Renowed Swiss Brands
BACK GLASS: Solid Close case back with Detailed Spitfire Graphic Engraving
Individual Live Serial Numbers and Matching Manufacturing Nos
HACK MOVEMENT: Yes
CLASP TYPE: Normal Tang buckle
DATE INDICATOR: 3:00 (Datewheel Font and Size is the same as the Genuine (Refer to Day 11)!!!
OTHER REMARKS:
Water Resistant
Running Secs at 9:00 Subdial
Chronograph (Faux Split Secs)
2:00 pusher - Start/Stop Chrono
4:00 pusher - Reset
Note: All Parts of the watch can be totally interchangeable with the Genuine watch
ACCEPT PAYMENT : PAYPAL / WU / CREDIT CARD / TT WIRE
CASE DIAMETER: 44mm
THICKNESS: 16mm
HACK MOVEMENT: Yes
OTHER REMARKS:
Water Resistant
4:00 pusher - Reset
