Is there a method to polish stainless steel?
btwn68n70
424
Still contemplating if I should reject this watch as the stainless steel looks "cloudy" and dirty...is there a way to buff it out? If you guys have a solution then I would not need to request a new watch :/
al358
627
15
I have always used a cap cod cloth then finished the polishing up with a little bluemagic metal polish cream and some cotton balls. Good luck with the direction you choose to go in.
rockpool
140
It's not so much cloudy, as bushed - if you want it reflective, you need a different model of watch.
houndoggie
344
you should not reject the watch as the watch is how it should be. QC pictures are to show the correct watch without any major flaws.
You can polish the watch when you get it, or have a jeweler polish it. Professional watch makers and jewelers do not polish things with cape cod cloth.
btwn68n70
424
haha I would feel bad for rejecting it...I approved it ;) thanks for your comments over at RG
kazin326
175
That watch is what is called brushed stainless. Polish won't fix that actually. It needs to be re bushed if it's not to your liking and that's nothing your going to be able to do well on your own
Bozz
2,748
If you want buy a nice watch at a cheap price, go with the sead PROMOs (TD Supermirrors). You can take a PROMO 390 @ $155 or a PROMO 360 (DLCed) @ $ 175.... a very good deal.
btwn68n70
424
I wanted a submersible :p
btwn68n70
424
thanks
watchismo
208
I have used different grades of auto paint polishes and compounds because that is what I have readily available in my garage.
bc1221
4,079
456
^^ same here. + A orbital buffer and a med grade pad.
you have to do some sanding with a high grit sandpaper firs though.
