Where is the 507? I seriously doubt this has a functional PR like the gen.
They might not show in the photos, but if you ask your TD, they should be able to confirm. I was thinking to get 616 before I got my gen dsotm and asked TS why photos didnt't correspond to description and in return 2 photos showing the new movement in that model.
Sent from the RWI App
Thanx for sharing... that well answered my concern... There shouldn't be 2 versions of P9000 from the same manufacturer...
There shouldn't be but there is. Either the reps get updated as soon as there is an available update or you have to wait until the current stock runs out, which can take awhile. But to make sure you're getting the new movement, you can ask the TD for pictures of the movement on a closed caseback model. Of course, the TD would not intentionally give you the older version when you specifically state you want the VSF PAM616 V3 /PAM498 V2/PAM389 V2 with the P.9000 super clone with gen function.
Agreed. Now i'm more concerned about when the old, bi-layered carbotech cases and CG are running out (if there's this one day) that I can get a PAM616 w/ bezel/case/CG that are more aligned w/ gen.
While v2 is functionally correct.
It's a pain to adjust date the "gen" way.
This might one of those rare occurrences where V1 would remain as an preferred option even after v2 release.
Haha this is so true! I choose not to wear them if they're more than 5 days off the current date![]()
