Identification P 3000 superclone
angiracca
121
A seller send to me this pics of the movement for a Pam 424 ,but I can not identify wich superclone is .
The image look different in some details form superclone 1-2-3-4 .Maybe superclone 0 ? Someone knows what superclone is?other_2048822397_00.jpg
PsychoTee16
-- Watchmaker --
Vendor (Watch Repair)
1,154
722
Louisiana
I will let the experts weigh in, but that is not a P.3000 super clone.
This may be an older model, but I would take a look at any of the trusted dealers websites, and you will see how a P.3000 clone should look.
angiracca
121
OK ,is different from the various superclone ,and therefore what movement is this? A 6497 decorated?
mysterio
9,794
864
It's an A6497 with decorative plates glued on. The true superclone P.3000 has the balance wheel @7, like the gen.
angiracca
121
Yes, Just like that, this is the watch that I found on DH gate for 135$. Is it worth buying it? or a bad deal?Wich factory make this424?
Sent from the RWI mobile app
angiracca
121
angiracca
121
angiracca
121
Yes,right but From the pictures does not look bad,also my Noob 372 has the same decorated 6497 and it is a good watch
mysterio
9,794
864
That's the operative word. From the pictures. Not all of the sellers on DHGate or Aliexpress are bad of course, but it's difficult to determine which ones are honest. The saying "you get what you pay for" applies. You might get what's pictured or you might not, in which case, good luck complaining about it because I doubt DHGate would side with you and in here, well, we told you so, right?
Don't compare a known quantity like the Noob PAM372 with an unknown like the ones in your pictures. The base movement of the Noob PAM372 and your PAM424 may be the same, so what? It's not the movement that makes the Noob PAM 372 that good, it's the dial.
angiracca
121
Ok thanks, I don't buy but is not easy to find a california Radiomir At an unreasonable price
mysterio
9,794
864
There's a reason why it's unreasonably priced, the quality is probably unreasonable as well.
