You can remove the movement first, then hammer in a rat tail file into the stock HR tube, and then use a pair of pliers to grip onto the rat tail file and unscrew the HR tube.
Once the HR tube is out, I recommend tapping the hole to ensure that gen-spec / athaya tubes can fit the threads. The proper Rolex tap for 7030 and 7020 tube is M3 x 0.35
You might need to make the hole slightly recessed so that the the new tube and crown can fit closer to the case.
if you are unfamiliar with modding, I recommend giving it to a watchmaker and let them figure it out.
Thanks for the help, but with due all respect, that will not work.
As I wrote:
From the case side,
Gen spec 7020 athaya tube is 2.85mm.
HR tube is 3.33mm
I make it really simple :
If HR case has hole to fit 3.4mm tube, 2.9mm Athaya tube is just completely loose and spins around, never threading into case.
Its really frustrating, I dont understand why HR has decided to drill such a big hole to a case, in my opinion its not gen spec.
On a sidenote about the crown :
HR claims gen crown fits to HR tube, but I beg to differ, athaya 702crown should be gen spec and that crown just simply does not screw in to HR tube, due size mismatch, Athaya crown is simply too big.
