- 21/8/20
- 149
- 292
- 63
Hi friends,
I have an simple solution to correct the sel fitting on all type of watch which normally comes from the gap between the spring bar and the sel end link.
To correct correct the gap or to tighten the sel to the case you just need to use a small bit of twine which you put between the sel and the spring bar.
Depending on the gap you can use one or two pieces to fit in the sell so that when you slide in the spring bar there is no free space left.
With this method you can also adjust the position of the sel fitting by putting the twine in various positions (up, down, left or right) of the spring bar.
Here some pictures to better understand what I mean
With this mod you can tighten the bracelet to the case so there is no moving or play between the sel and the case.
Hope this can help you
Thx.
Thx.
