How to make Rolex glidelock work smoothly?
Newguyhere95
100
100
Hey there,
I just received my 116613lb, everything works well except the Glidelock system, it’s very hard to adjust, what did you do to fix it?
I am thinking about using WD-40 for it, don’t know it’s good idea or not.
Can you help me out? Thank you
And Ad delete this thread if it has been posted before.
AggressiveTiger
89
67
I wouldn't use WD-40. Try a baby oil bath first:
Reactions: Newguyhere95
mmaggi
1,002
807
New York, USA
The glide lock on these reps are a pain in the ass. I have one on my CF Sub-Date that works great but one on my NOOB Hulk that's bad one on my CF Daytona gray dial rubber strap (that I bought from ALI) that works like crap as well. PITA.
36,955
77,169
I use a furniture wax stick, the kind you use on drawer rails to make them operate smoothly. Just rub some in the sidewall grooves and work it in. Any liquid lube or oil is just going to attract and retain dust and grime.
Newguyhere95
100
100
I got my Clean Starbucks not too long ago, the glidelocks work kinda smooth. This Bluesy glidelock don’t work well i guess. Bluesy also from Clean factory too.
Newguyhere95
100
100
Thank you. Appreciate it 👍
Newguyhere95
100
100
Thank you
Reactions: AggressiveTiger
RoXeW22
142
109
I would definitely not use WD-40 as it's not a lubricant. I recently had this issue with a few of my reps and "dry lube" worked perfectly. Also, I would not use Vaseline
Newguyhere95
100
100
Thank you for advising guys, I tried some steps and it worked out perfectly. Able to slide so smoothly now. 🫡
