I know exactly what you are describing! I discovered it the other day..that litte piece must slide and kind of snap perfectly into place...well on my PO, my clasp wouldn't stay closed. I think this is the problem for many people that have tried the clasp mods. I was headed there until I found this. Works perfect every time now!Are you clipping it in properly in the first place? I know that sounds like a stupid question, but I've noticed on omega's (gen and rep) that I've owned and handled, that the deployment will still close if the DE is not tucked under the 'stop' properly...
A little hard to describe with no watch to take pictures of and demonstrate what I mean.... The DE should be dropped into the clasp at about a 90 degree angle and then laid flat - the deployment should then close tightly over the top with a nice tight 'click'....
Apologies if this is not even close to what you're talking about... But worth a try![]()
