How many times to wind Swiss Unitas 6497?
mrsato1
So I just purchased a Davidsen-DSN PAM 111H with Swiss Unitas 6497. How many times can you wind the crown without breaking something inside the watch?
bkwatch
68
around 20 full turns towards 12
KBH
7,168
41
You will feel it slowly get more resistance. When it reaches fully wound it will stop and not go any farther. You can't break it unless you rally try hard to wind it after it stops.
Fiddo
Mythical
7,995
3,761
In a Causal Loop
If it is completely unwound 50 turns will wind it. It will stop (can't turn it anymore) when it's fully wound. It won't break if you fully wind it...don't worry.
COLDI
9,711
118
Turn it until it gets tight then stop. To wind it to much you will have to really want it. You will know by the feel.
Drulee
648
If you turn the crown (CW) about 30 turns, then start to turn the crown slowly. You will get to a point where you can tell you've hit significant resistance. Stop. Your 6497 is now fully wound, and you are less likely to overwind by doing the last bunch of turns slowly.
Of course, this assumes you are starting with a fully unwound state.
