How many links should a clean GMT II batgirl with Jub bracelet have?
sirjamie
14/11/20
Hi experts
I just purchased a
ROLGMT0298 - GMT II 126710 Batgirl 904 Jub SS/SS Clean DD3285​
My question is how many links should this watch have. There are not enough to fit my wrist and l have never had any issues with watches not fitting before.
I'm wondering whether my watch came with the currect number of links - there were no spares in the packaging.
17,327
Hi experts
I just purchased a
Set the microadjust to the last hole and then use the ez link extension to see if it helps.
TerryRobot
446
349
The will have a normal amount for a standard size wrist, as Reaps suggests this can make it a little bit bigger, but buying another link will proabably be better, ebay or Ali will do some as they will be pretty standard, might be easier to look on ebay and just buy a second bracelet then you can add as many as you like either side to level it up.
The extension link is handy in the summer when we all swell up a little in the heat so it allows a little more wiggle room or it allows it to be worn over a wetsuit if you do that type of thing!
Good luck
Big_Pilot
251
175
Had the same issue on my Clean Pepsi.......after it arrived I thought....WTF!!!
How can the watch band be so tight?
I don't have such huge wrists? Never had this problem before. Was also my first Jubilee bracelet watch.
So contacted AD I ordered it from (InTime) and asked him for some additional links.
Ordered one link, he send me two links, I ended up using one.
