I bought an Omega Seamaster P.O quartz with working chrono. Lovely watch but the chrono is JUST short of 12 o'clock. I've tried the usual, pull the winder and use button A to center, but I can never get it dead on 12
I have two Seiko chronos. Sometimes the hands don´t reach the 12 o´clock position. In this case they have the possibility to let the hands run smooth around, and when reaching the end position I release the button and the hand stops at desired position.
So pull the crown and try to press (and hold) the start/stop button. When the hand runs you can adjust it in smaller steps if you press the button again only once (second by second). You need some time to find out how it works
Good luck
Try this page for manual and search for the 7T32 Analog Quartz Caliber: http://www.seiko.ie/page.php?n=59
You can choose other languages, too
gotta open it up, remove the chrono hand and reset it...takes about 10-15min if you got the tools and balls to do it. I just did it last night on a quartz PO chrono I got.
