Hi
I took the plunge on a PAM320, which looks sweet (see attached photos). I am not too bothered about it being perfect cosmetically in every way - it looks gorgeous enough to me. However I want the watch to perform to acceptable levels.
Photos:
http://forum.replica-watch.info/vb/attachment.php?attachmentid=8020&stc=1&d=1348929544
http://forum.replica-watch.info/vb/attachment.php?attachmentid=8021&stc=1&d=1348929544
http://forum.replica-watch.info/vb/attachment.php?attachmentid=8027&stc=1&d=1348931232
I have looked at various generic explanations of timegrapher data, and it seems to me the Amplitude and Beat Error values are within acceptable levels. However the Rate value is +12 sec/day (I am assuming "+012" is +12 and not +0.12?) and the Lift Angle is 53 degrees. I heard somewhere that if the lift angle is not correct the rest of the data may not be representative enough. Could someone please confirm:
1. Is 53 degrees an acceptable lift angle for an Asian 7750 auto 28800 movement? (I cannot find this info anywhere on the web.)
2. Is +12 sec/day an acceptable rate for these movements? (If it means I will lose 1 minute every 5 days, I would say that is perfectly OK... My friend's gen Rolex Submariner goes out by that much within a day!) Does+12 sec/day on the timegrapher translate into +12 sec/day on the hand, or will it be more/less?
3. Finally, could anyone confirm if the movement is Shanghai or Liaoning 28000 (I suspect Liaoning)? I hear Liaoning is not as good as Shanghai but is it "acceptable" enough?
Thanks in advance!
Photos:
Thanks in advance!
