Help with identifying factory of PAM372 needed
Malaka
112
45
Hey guys,
can you help me in identifying this PAM 372?
Checked the bible but did not see which factory could fit.
Thanks
Benjamin
Malaka
112
45
This is the movement from the ZF at Intime:
And this the one from my post:
To me, my 372 looks more like a covered Unitas.
No?
ceesq
725
34
Also not ZF, its a A6497 movement with some deco plates to look like P3000, its a cheap version dont know the factory
superspark69
3,183
2,249
Sheffield, UK
Noob has a 6497 but this one is not a noob, the noob had the correct case shape best dial but least accurate movement, this one looks cheaper....
PAM_BOY
10,949
31,663
To me it also seems to be an covered ST36! Definitely no NOOB!
Here the original P.3000
Malaka
112
45
OK. So, if is not a known factory, I will most probably leave my hands away. Especially for 300€...
Thanks guys!
PAM_BOY
10,949
31,663
Never seen before ... screw heads on the wrong side and no year / run number on the caseback,
(Very attentive from superspark69)
STRANGE:eek:hwell:
KOT1917
3,395
5,533
Russian federation
This is a DHGATE sample for $ 120-150. Please note that instead of jeWels, jeSels is written on the decorative plate. Ask for a photo of the engraving between the eyes, not sure if they will be true.
mysterio
9,793
867
STRANGE:eek:hwell:
The watch could be using spring bars. You can't reverse the lug screws as the head side of the lug screw won't fit the threaded hole and you would see it sticking out.
Malaka
112
45
Just got an info that Intime still was 372 from ZF. Will get this one. Maybe an additional Noob from M2M.
Then I can compare it with my Gen which I want to sell ;-)
superspark69
3,183
2,249
Sheffield, UK
regardless, it isn’t a good one so I would hold out for a noob on m2m
superspark69
3,183
2,249
Sheffield, UK
Noob is best compared to gen, let me know if you sell the gen ;)
