I went onto the vintage Omega website and pulled the specs on the 2531.80.00 bond watch and it does say one side coated AR. Now this covers 1993-2004 or around and about so it may be that the earlier models with 1109 caliber did not have AR and then they made a switch in 1994 with caliber 1120. I would suspect since OttoFrei offers nothing other than an AR crystal replacement for the case #'s associated with 2531.80.00 that if they had no AR crystal for sale as a replacement, then it is appropriate/accurate to have AR on this watch. In other words if someone called you on it (who cares if they did) you could mention the crystal is OEM and has been updated. I hope that makes sense.
