Help with A7750 needed.
hussamsaidan
22
Greetings
I just received my first rep today from watch station and I think there is a problem with the watch when ever the long seconds reaches second 56 the watch stops completely and I have to re push the red button to start it again and there only seconds at 9 chrono works and the whole each stops you can see the problem clearly in the attached videos https://vimeo.com/173155379https://vimeo.com/173155395
ofc i couldnt notice any other chrono working other then seconds, which really pisses me off.
Can someone guide me thru this and tell me what to do to get this thing fixed please?
Thanks in advance
ZoomBoy
2,533
288
Don't use the chrono in the 7750 movement. Is the rest of the watch running fine? If yes then leave it as-is.
KBH
7,168
41
Two choices. Send it back for repair or try to find a qualified watch smith to fix it locally. Either way it's going to be a pain in the azz.
hussamsaidan
22
im not using the chronos, but it forces me to when the long seconds stops at 56, and if i leave it it will stay there for as long as i leave it, i have to reset it, to start again and it will just stop after 56seconds of running, and sending it back might be the option for me just to cause them a little pain as they did to me.
hussamsaidan
22
Now the watch stopped working completely
KBH
7,168
41
You obviously are using the chrono since the long second hand only moves when the chrono is working.
apollo1965
136
26
The long second hand is the chrono seconds hand, you don't see the other chrono dials moving because they count minutes and hours, but as your stops a 56 seconds then needs reset the other dials will not move. The general consensus on the A7750 is not to use the chrono.
raxford
60
So just to recap:
The seconds for the watch are in the little circle at 9:00. You're using the stopwatch by pressing the red button.
Two things -
Yes, there is something wrong with the movement because it shouldn't stop like that, however the 7750 movements are known to be crappy when it comes to using the stopwatch. It's just an unfortunate reality of saving $3-4K on a watch.
HOWEVER, the seconds appear to be working fine.
So you have two options as has been suggested:
1. Send it back for repair/replacement. This takes a ton of time to do. I personally would not choose this option.
2. Stop using the chronograph and be a little bummed about it.
Either way, sorry this has happened to you. Buy from the forum in the future and you will have better luck.
ado213
714
185
Your problem lies in the chrono gear, part no 8000. The minute jumper lever attached to the chron gear is bent at the wrong angle, it's hitting at way too steep an angle. These can be tricky to adjust, just buy the gen eta part and fit it.
hussamsaidan
22
Thanks a lot for helping me out on this , will be looking for some gen parts for replacement, seems like the best way to go other then buying the gen watch it self, thanks a lot guys been a great help
Cheers
RG417
1,851
11
Maybe get an eta 7750 and install cos that's a nice watch.
bhanu200bc
2/4/16
I recently bought this same replica with all working chronograph.. What colud be the movement used in this watch.. Its a quartz movement for sure..im in india and the market here is very poor on replica.. So want to order a good replica movement and replace the inside movement.. The watch costed about 50$°°..so i doubt it has a good movement inside.. Im a noob basically.. But im catching up on stuff in all forums..
Sent from my ONEPLUS A3003 using Tapatalk
bhanu200bc
2/4/16
Plz suggest aa good movement model so i will replace the whole inside with a reliable movement.. And also drop links if possible... Thank you
bhanu200bc
2/4/16
This is the watch i purchased.. Mostly a quartz movement..
Robb
787
Whats the quality of your watch & bracelet to the Gen have you compared it
Does it have some weight how does it feel in quality ?
Thanks
Rob
Sent from the RWI mobile app
