Help with a panerai replacement part?
brahmabull
On the hunt for PAM163,212,213,288,286,253,228,297
1,251
3,441
Tar on toe
Hi everyone.
Need your help/advice on getting a replacement part for my Panerai Ferrari watch. One of the knobs came loose and fell off.
Not sure where to go/what to do? Any suggestions? I’m based in Toronto, Canada
Thanks in advance for your help/suggestions
Rx4Time
Supporter, Panerai lover
12,158
11,286
Do you have the parts? It's going to be virtually impossible to get that part so if you have the one that fell off, I'd consider sending it out to reinstall if possible or glueing it on if not. (as much as I hate the idea of that).
Plaasbaas
IWC-hoarder and PAM-hunter
3,279
7,924
As already has been said, I really hope you still have that pusher. It will be almost impossible to find a replacement :-(
onsight
169
127
If you could take the other pusher off, someone with a lathe may be able to make a duplicate.
brahmabull
1,251
3,441
Tar on toe
Thank you for the suggestion. I may look at using Daytona pushers from Ali express as an alternative solution
