- 4/7/09
- 1,075
- 614
- 113
I bought a Pam 111 in an M2M sale a few years ago which was DOA. I finally got around to sending it off to Katt to look at and he came back with this:
"I got the movement to run just fine. The metal retaining ring is causing all kinds of problem however. If I tighten down a screw then the set -wind function will not work wen you pull the stem back and forth. I tried sanding down the ring that didn't help either."
Has anyone come across this issue before? Is it common? Is there a fix? Where can I source a replacement part?, etc. I'm afraid I have no idea which factory made the watch or any other information on it.
Any advice or help at all would be greatly appreciated.
Z
Z
