HELP: What part of bracelet is?
ratpatrolteam01
831
32
I just bought a watch and noticed one of the spring loaded ball/bearing is missing. I love this watch and I want to get this fixed!
http://img716.imageshack.us/img716/8311/155im.jpg
Anyone know what it's called and where I acn get replacement parts? or am I SOL since it's proprietary or something... I hope a jeweler can fix it!
It looks to be a ball-bearing of some sort with a pin + spring inside it that gives pressure to the fold-over clasp to keep it closed. However one set is missing other is present. Is there a way to get replacements for this?
scavenger
17/9/12
Can't really tell from the pictures, but the part of the bracelet you are referring to is the micro-adjustment bit, isn't it? Is the bracelet not working properly? What I am getting at is whether's there's actually a pin that goes into that bit, or if it's meant to be open unless you move the adjustment part in to slightly shorten the bracelet.
I think I recall seeing some information on this - let me try to dig it up and if I find it I'll post it here.
Scav.
ratpatrolteam01
831
32
It's not the micro adjustment bit actually. It's the part where it holds the fold over clasp by applied pressure. Like a ball bearing pushed out by a very small spring and pin. The pin and spring though is separated by two pieces not a single piece.
Thanks thougj
ratpatrolteam01
831
32
Sorry the link is broken
So it's the bearing / ball (Which I believe is being pushed up by a spring + a pin) that adds pressure to the Bracelet Clasp that keeps it snapped shut / closed.
It's missing on one side. I was wondering if I have to get a new bracelet for this?
