Help understanding QC meter numbers
CSpring
7/8/23
13
NY, NY
Hello
Can someone point me to a thread explaining beat number, amplitude, lift angle, etc?
dpd3672
1,936
3,236
This is a subsection of the FAQ, but the entire thing is great as a reference guide.
kavorca1
cosa nostra for life.
2,524
3,282
SoCal
So you've got the QC images or your brand new best replica, like, ever, with that incabloc you always dreamed of, as swiss as cheese, but what about your timegrapher results? What dahell are those?
Presets
Beat Number
Frequency, the vibration of a movement. The number of balance wheel swings per hour or how many times the watch ticks per hour. This is a preset, depends on the watch you order.
14,400 bph = 4 beats per second
18,000 bph = 5 beats per second
21,600 bph = 6 beats per second
28,800 bph = 8 beats per second
etc
Lift Angle
The angle the balance passes through while interacting with the pallet fork. Important to be set correctly in order to calculate the Amplitude. This preset is per caliber specs.
Most modern watches have a lift angle of 50 - 52 degrees. Generally lift angles range from 44 to 58 degrees. Some other settings are present, for instance Gen co-axials angle is 30 degrees.
Results
Rate
How fast / slow the movement runs (in seconds per day)
great : +/- 5 s/d
acceptable : +/- 12 s/d
If higher / lower?
It is possible to adjust this yourself or ask your dealer to nudge it a bit.
Amplitude
The measure of the amount of rotation in the swing of the balance wheel, in either direction.
Amplitude is higher when a watch is lying flat and usually falls when the watch is in a vertical position, due to increased friction. Amplitude can also fall as the watch winds down and the mainspring delivers less power.
Amplitude is a good indicator of the movements health and if is too high or too low, or that changes too much in different positions, can indicate a problem with the movement.
great : 270-310
acceptable : 250-270
If higher / lower?
Ask for a different watch or have your watch serviced
Beat Error
The amount of time by which the duration of swing differs from one side to the other in the oscillation of a balance wheel. Generally speaking to get a beat error of zero, the roller jewel in the pallet fork must be perfectly centered.
great : 0.0-0.5 ms
acceptable : 0.6-1 ms
If higher?
Ask for a different watch or have your watch serviced.
* Please note that if you are reading your QC from the dealer, you will generally receive only the results of the watch lying flat. All the above recommended measurements are from that position. The measurements in other positions may vary
Fabulously
573
1,467
Lalaland
Hello
I always like to refer to this nice overview:
Reactions: CSpring
eBoy
15,228
25,781
Hello
Don’t obsess too much over those numbers though. They are just a snap shot of your watch in a single position. That's not how the performance of a watch is measured.
The timegrapher photo in QC should be understood as proof that the watch works and that there isn't something grossly wrong with the movement. Nothing less, nothing more.
The values in a single reading, in a single position with an unknown state of charge of the main spring are as accurate and useful to measure the true performance of a watch as a photo of a car's speedometer at 90 km/h is.
The photo just tells you that the car works and not really how well the engine performs or anything more than that. The timegrapher shot in QC should be viewed as the horological equivalent of that...
Qomplete
17
15
Legend
