help needed with PAM111
hiko
29
Hi guys,
i am looking at a pam111 V4, could someone suggest if its worth paying a little extra for V4 over a V3?
or share your experience with either and your thoughts?
Cheers
AL0HA
890
15
When I was searching for the 111, the general consensus was that there was no real V4. Most were either s mashup of of different parts, or V3. Was going to go with BK, but found another PAM I ended up getting instead.
hiko
29
this is also what i read.
saw a TD that is selling a: Noobfactory Pam111 N V4 1:1 Best Asian 6497 with Y-Incabloc (dunno if allowed to name the TD) but this V4 also uses the 6497 movement instead of the P3000 that most noob pam111 uses.
hiko
29
btw am not sure if i am allowed to compare 2 watches that (i think) is the exact same model from 2 TD however their prices are $188 compared to $248 which is quite a big difference. not my place to say but when i was researching prices for the same watch is usally around $10 difference between TDs.
mysterio
9,794
864
No noob PAM111, whatever version, is using a P.3000. The gen uses an OP XI Calibre movement, which is copied by the factories with the A6497 movement.
bangsters
2,013
21
I'd go for bk pam 111. It's pretty much a noob pam 111 v3/4 woth some bk enhancements.
hiko
29
I went and ordered the v4 with the Asian movement. Hope I made the right choice over the p3000
bangsters
2,013
21
Did you get the 188 price or the one that's a bit more? I would go for the more expebsive one, as others have said the noob pam 111 cost mid 200 at any TD.
bangsters
2,013
21
